Current.variables.<variable name> not working in my catalog item's workflow
‎07-10-2017 01:32 PM
My workflow has an "Approval User" activity with a script that uses a Gliderecord to filter a table
Here is my code:
var target = new GlideRecord ('u_application_table);
target.addQuery('name', current.variables.what_app_name);
target.addQuery('u_permissions', current.variables.what_permissions);
target.query();
I'm trying to use current.variables.<variable name> in lines 2 and 3 to pull the values of the variables what_app_name and what_permissions. If I replace them with a string like 'hello' I do get results but doing it the way I do above gets me nothing. Am I doing something wrong? These variables are lookup select boxes that reference two columns in my application_table table. I'm wondering if the fact that they are references is whats messing something up.
‎07-11-2017 11:48 AM
I also ran this in a background script and got the correct value for my variable.
gr.addQuery('number','<MY RITM #>')
while(gr.next()){
gs.print(gr.variables.<MY VARIABLE NAME>);
‎07-11-2017 12:02 PM
i am able to get the result when i do this on sc_req_item level.
that's coming in my log
‎07-11-2017 12:04 PM
sys_request or sc_request? it's sc_request
‎07-12-2017 07:10 AM
sc_request yes. So I resolved my problem by switching my workflow to the sc_req_item table. Now when I run current.variables.<myvariablename> I do sucessfully return the value!
Now I have a new problem because even though the workflow for the RITM is running, it isn't being run unless the Request is approved and that doesn't automatically happen anymore for some reason. I have to manually approve it at the request level for the workflow to trigger at the RITM level. This functionality broke when I switched my workflow's table from sc_request to sc_req_item
‎07-12-2017 07:17 AM
does the request have any workflow at all running??
we have one workflow that runs on the request.. this checks to see if managers approval is required <we trigger this with a variable on the items> and if not marks it approved.
if you do have a workflow running on the sc_request table check it and make sure it triggered... you may have an exception for this item on it.
do you run all of your item workflows on the sc_request table? or just this one?
