Customization of Project Status Portal in PPM
raj1989
Hello All,
There are default columns in the project status portal like Number, Short Description, Manager, Portfolio, Percent Complete, Planned Start Date, Planned End Date, Overall Status. If I want to add the new columns or the customized columns in the project status portal. What is the process? How can I do that?
20 REPLIES 20
Thanks for your response. Actually 'state' column is adding but other columns like, 'primary_program'   and the 'u_project_sequence_number' (custom field)is not adding. I am not getting why this were not adding.
Hi Abhishek,
Your advice was helpful for me in adding columns to the timeline as well as the summary. I am now having an issue with my custom columns not showing the correct value. In the screen shot you can see my project manager fields showing the sys_id instead of the user referenced. Same with project status and the the date fields which is a custom Actual Start Date. Any thoughts?
Hello Abhishek,
I have a question about how to link the Project Service portal to the filter navigator. I've seen this before but can't find the right place to update the page.
This is the link I have to my service portal.
/project_status?id=pps_psp&sysparm_show_all_projects=true&sysparm_title=Project%20Status%20Portal&sysparm_sys_class_name=pm_project
I would like to be able to reach it from the filter navigator.
any help would be appreciated.
Spencer
harishdasari
Hi Raja Reddy,
There is a UI page exists with name   "psp_overview".
https://yourinstance.service-now.com/sp_config?id=page_edit&p=psp_overview&table=sp_instance&sys_id=...
Copy the link and put your instance in the url, it will navigate to service portal. here you can find the fields in JSON format.
Hope this might be helpful
Hello Hari,
I have added and saved the column but it is not reflecting in the project status portal. After saving, is there any process to do.
