Dashboard View not visible in homepage
tulasi8
Hi Community,
Our production instance was upgraded to newer version , now the users want the dashboards needs to come automatically in homepage when login into ServiceNow instance , how to achieve it.
Current view :
They need in dashboard view how it was earlier . Can anyone please help on this .
Tulasi
@tulasi8
I already mentioned that homepages are not being used now by many customers
You need to convince customer to stay with the latest trends or else they will miss the new features
16 REPLIES 16
@tulasi8
Tanushree Maiti
Hi @tulasi8
Refer: KB0744970 Set your startup screen on a ServiceNow instance
Dr Atul - LNG
Hi @tulasi8
https://www.servicenow.com/docs/r/platform-user-interface/configure-per-user-ui16-landing-page-in-ne...
Setting Global Default
  • Go to All > User Administration > User Preferences.
  • Click New.
  • Set Name to my_home_navigation_page.
  • Set Description to Set default dashboard for new users.
  • Check the System box (leave the User field completely empty to apply as an instance-wide default).
  • Set Type to string.
  • Set Value to $pa_dashboard.do (or paste a specific dashboard sys_id if targeting a single fixed dashboard).
  • Click Submit
Alternative Method (System Properties)
  • Navigate to System Properties > **System Properties [sys_properties]` list.
  • Locate or create properties like glide.login.home or glide.home.page.
  • Set the property value to your target dashboard URL or $pa_dashboard.do
tulasi8
