12-29-2020 04:03 AM
I need to import data load and transform map through catalog item. When ever user submit a request with attachment the data should load through transform map via ritm only.
Please suggest how it possible.
Hari
Service Catalog
12-29-2020 04:15 AM
I have written article for same
Refer that and do the steps mentioned in that.
Please mark it helpful as well
Data load and transform via Catalog Item
Just one thing to remember if you are doing your catalog item in scoped application then you should allow Can Delete access
01-11-2021 03:34 AM
Thank you.
01-11-2021 03:39 AM
So are you having anything in the excel to determine the domain?
And also record which is imported craeted by showing sysytem not requested for user.
a) this is the default behavior
01-11-2021 03:52 AM
Yes Ankur, We are fetching the domain of record in that excel.
And also record which is imported created by showing system not requested for user.
A) No it's not a default Behavior. when we import manually it will show who is created by.
Varma
01-11-2021 04:11 AM
but as per the flow/steps you have configured as per my blog the transform would trigger via script and hence it would show system
01-11-2021 04:25 AM
Thanks Ankur,
Is there any way that we can show the requested for name or dynamic user name.
And also how to stop picking the wrong domain manufacture.
Varma
