Data Policy error in problem form
Vivekavardhan R
I am facing this issue where I click on "Fix" when the problem form is in "Fix in progress". I am getting the below errors. I have checked the data policies but they are good. As an admin user, i dont have this issue. but others are facing this issue.
HI @Vivekavardhan R
Did you use these two fields, ‘Cause Notes’ and ‘Fix Notes’? Since they are mandatory, make sure to fill them when the state is ‘In Progress’
Ankur Bawiskar
@Vivekavardhan R
it clearly says both fields are mandatory and data policy should behave same for admin and non-admin
share what debugging did you do?
