Deactivate Inactive users automatically using a Flow Design
jeffreygard1127
Hi fellow ServiceNow practitioners,
I'm an Intern and fresh from my one week boot-camp in ServiceNow. I am trying to accomplish a task where in I need to create a flow design that will deactivate inactive users if they haven't login for more than 2 weeks. But I need to use a sys property and incorporate it in the flow design.
The sys property should have a formula like this:
If Last Login date is < (Current date - value from sys_properties) = deactivate user.
Right now, this is what my flow looks like but I am not sure if this is right. I'm also not familiar on how to create a sys_property and how to incorporate the sys property into my flow design.
Mark Roethof
Hi there,
To get the value of a System Property, you could just perform a Look Up Record. With that, you can use that value elsewhere in your Flow, for example on your condition for the X days.
Hi Sir @Mark Roethof, thank you for your response. I'm actually not familiar with that since this is my 1st time to create a flow design, could you please teach me how to do it?
Hi @jeffreygard1127 ,
You should modify your search condition in Lookup Records action, where you are searching for inactive users.
you have to add a filter to search for user where lastlogin is before 1 days.
it should look like the below screenshot, add this condition.
Hi Sir @Community Alums, Thank you for your response. My task requires a sys_property for the 14 days and not just a filter on the condition. Do you have an idea how to do it? It's my first time to create a flow so I'm not familiar with this.
