Decision Tables not working in Flow Designer
BrianS344076034
We recently started to use Decision Tables.
We have created a table to look at an employees department, and based on that assign a catalog task to the right team
We have some departments that have a specialized Service Desk, so instead of those Onboarding and Exit alerts coming to our main help desk, we want to move them to the right team / agent.
In Dev its setup with the following
Department name - Reference to CMN_department
Then we have our columns as Department Name as the input, and the output being Assignment Group and Assigned to
If the department is not in the list, default is to assign to Service Desk
Then in the flow we have it going
Get Catalog Variables
Make a Decision
Decision input looks like this
Department - Get Catalog Variables > Employee > Department
this is working, it runs the flow and if it matches it puts the task to the right group
I moved this to PRD and it lost the inputs, so I rebuilt the exact decision table
But this time, it will not let me dot walk or drag the appropriate Pill over for the variable.
Ive tested on the lastest version of Chrome and Edge
Both my Dev and Prd environments are on the same versions of the platform
Production has Workflow studio 27.1.4
Dev has 27.0.8 installed
its only the dot walk and pill for Decision tables that is not working.
Any ideas?
Vishal Jaswal
Tera Sage
Hello @BrianS344076034
In Dev and Prod, validate records related to your decision table in below tables:
Decision Input: sys_decision_input
Decision Table Conditions: sn_decision_table_decision_condition
If there is a mismatch then export them as xml from dev and then import into production. If it starts to work then validate the customer updates in the update set whether these were captured or not and if not then you can troubleshoot or raise HI Case.
Ankur Bawiskar
@BrianS344076034
Sometimes there are challenges when you migrate decision tables and those are not migrated properly.
are you sure the decision table is exact copy in PROD?
it should allow you to map it with reference field since you are trying to populate Assigned To and Group field which are both reference type
share screenshots
BrianS344076034
To be safe I built it again from scratch and manually reselected everything
its something to do with the version of Workflow studio I believe.
It just will not allow any pill to be placed in the box
we have another Decision table for another process, that we just did a copy of, and its the same thing. It will not allow us to put a variable in the selector.
Has to be tied to a bug
Nicole Disbro
Any updates to this? I am experiencing the same error
