Default value on Yes/No variable
Karan31
How can we set No on Yes/No variable on variable form page. Since i am using UI policies to control the visibility of the field. I don't want to use client script for this.
9 REPLIES 9
Just checking if this answered or not?
-Anurag
Prasant Kumar 1
Please follow the below screenshot for setting dafault value for Yes/No type variable.
If I was able to solve your query, please mark my answer correct and helpful.
Thanks & Regards
Prasant Kumar Sahu
PratyushaBodepu
Mega Guru
You can just use the variable configuration to achieve this. Put 'No' in the default value in the variable.
Also, if you don't want 'None' in the dropdown, you can configure using the checkbox 'Include None' accordingly.
Pratyusha
Anil Shewale
Mega Guru
Hi
you can write onload client script on form.
example
function onLoad() {
if(g_form.isNewRecord()) {
g_form.setValue("fieldName",false);
If it help mark helpful or correct
Thanks and regards
Anil
Was having the same issue and had to switch the "Clear the variable value" on my Catalog UI Policy Action to false (when making it invisible). Then had to check "Run scripts" and on "Execute if true" (invisible condition satisfied) added:
g_form.setValue('yes_no_field', 'No', 'No');
