Dependent Values lookup
George56
Hello,  Was wondering if some one could help me with retrieving a list of sub-categories based on their dependent value.  Basically I have a catalog item where you pick a category and I want the sub-category list to only show those associated with the category.
Mahesh23
You can try below method
For category
Variable type : lookup select box
Lockup from table : choice (sys_choice)
Lookup value field : value
lookup label field : label
reference qualifier: element=category
if table specific
reference qualifier = name=incident^element=category
For subcategory
Lookup label field: label
reference qualifier: javascipt:'element=subcategory^dependant_value='+current.variables.'CATALOG ITEM CATEGORY VARIABLE NAME'
if table specific
reference qualifier = javascript:'name=incident^element=subcategory^+current.variables.'CATALOG ITEM CATEGORY VARIABLE NAME'
variable attributes: ref_qual_elements=CATALOG ITEM CATEGORY VARIABLE NAME
Mahesh
11 REPLIES 11
George56
Both values are being pulled from our Software Product table.  I have both defined in my catalog item as Lookup Select Boxes.  For Category the Lookup from table is Software Product and the Lookup value field is Category.  For Sub Category the Lookup from table is also Software Product and the Look up value field is Sub Category.  I added the provided Reference Qualifier and Variable Attributes to the Sub Category variable and it returns all Sub Categories.
Use :
javascript: 'category='+current.variables.v_category
Assuming category is backend name in software product.
Mahesh23
You can try something like mentioned in the attachment images
Mahesh
Mahesh23
You can try something like mentioned in the attachment images.
Mahesh
Mahesh23
For category
if table specific
For subcategory
if table specific
Mahesh
