Dependent Values lookup
George56
Hello,  Was wondering if some one could help me with retrieving a list of sub-categories based on their dependent value.  Basically I have a catalog item where you pick a category and I want the sub-category list to only show those associated with the category.
Mahesh23
You can try below method
For category
Variable type : lookup select box
Lockup from table : choice (sys_choice)
Lookup value field : value
lookup label field : label
reference qualifier: element=category
if table specific
reference qualifier = name=incident^element=category
For subcategory
Lookup label field: label
reference qualifier: javascipt:'element=subcategory^dependant_value='+current.variables.'CATALOG ITEM CATEGORY VARIABLE NAME'
if table specific
reference qualifier = javascript:'name=incident^element=subcategory^+current.variables.'CATALOG ITEM CATEGORY VARIABLE NAME'
variable attributes: ref_qual_elements=CATALOG ITEM CATEGORY VARIABLE NAME
Mahesh
11 REPLIES 11
Does this look right?
Category
Reference qual
name=samp_sw_product^element=u_category
Sub Catgeory
Reference qual
javascript:'name=samp_sw_product^element=subcategory^dependent_value='+current.variables.v_category
Variable Attributes
ref_qual_elements=v_category
George56
Thanks you all.  I was able to get it to work using the suggestion by Mahesh.  I realized when I first entered the information I was using the Lookup label field Label(uppercase) rather than label(lowercase).  I also found in the Reference Qualifier for Sub Category I was using the wrong element.  Thanks again
