Dev Instance re-adding color and banner
ramba-hites
How Can I Update Dev Instance to re-add color and banner indicating it is Dev instance . It is next experience instance. Provide the proper solution for it
Thank You!
Hitesh Ramba
Hi @ramba-hites ,
Please use below CSS file, I'm adding the whole 2000 line in that file this will work you.
Copy and paste that css in that
Please mark my answer correct and helpful if this works for you
Thanks and Regards
Sarthak
ramba-hites
I couldnt see anything i  added red color but it is white , how can I solve this
Hi @ramba-hites ,
Did you make the changes here only ?
In line 1922 you have to change the value not key I hope you did like this only  "--now-unified-nav_header--background-color": "228,35,56",
Because there is twice the name coming now-unified-nav_header--background-color, we don't have to change the key we have to change the value here
Thanks and Regards
Sarthak
Hi @Community Alums
I dont have those many lines only 1300 were there
Hi @ramba-hites ,
Thanks and Regards
Sarthak
