Difference between 2 dates in days in catalog client script
soumyadaggula
Hi team ,
I am trying to get the difference of 2 dates in days , I tried below script , but its not working :
Catalog Client Scripts
var answer;
var ga=new GlideAjax('NofDays');
ga.addParam('sysparm_name','days');
ga.addParam('sysparm_start',g_form.getValue('u_date'));
ga.addParam('sysparm_end',g_form.getValue('audit_last_test'));
ga.getXMLWait();
answer=ga.getAnswer();
g_form.setValue('audit_required_timeframe',answer);
Script Include :
var NofDays = Class.create();
NofDays.prototype = Object.extendsObject(AbstractAjaxProcessor, {
days:function(){
var start=this.getParameter('sysparm_start');
var end=this.getParameter('sysparm_end');
return gs.dateDiff(start,end);
type: 'NofDays'
Mohith Devatte
Tera Sage
Hello @soumyadaggula ,
can  you try this in script include ?
days:function(){
var start = new GlideDateTime(this.getParameter('sysparm_start'));
  var end = new GlideDateTime(this.getParameter('sysparm_end'));
  var diff = GlideDateTime.subtract(start, end);
  var days = diff.getRoundedDayPart();
return days;
type: 'NofDays'
Hope this helps
Mark my answer correct if this helps you
Hi @soumyadaggula ,
You can split the response to obtain just the number part. See below:
var days = comments.split(" ")[0];​
Mohith Devatte
Tera Sage
days:function(){
return days;
type: 'NofDays'
Hope this helps
thank you So much Mohit , this is working now as expected , thanks a Ton !!
