12-25-2019 08:47 AM
Hi Team,
I would like to understand the dfference between Catalog item and record producer. And advantages,
thanks,
Anand Kumar.
Service Catalog
12-25-2019 09:30 AM
Hello Anand,
1. Catalog Item will end up in opening a request and reqeust item and attaches a workflow and catalog task, approvals Where as a Record producer simply insert a record in the selected table.
2. With catalog item, You can add multiple items to cart and generate request and multiple RITM's. where as a record producer it only creates a single record on target table
3. Primarily, the difference is which type of record is created upon submission. I would use a catalog item when you want to generate a request, complete with a workflow, approvals, tasks, etc, and a record producer when you want to gather some information using a form (variables) but create some other type of record (incident, change, enhancement, etc.) as a result.
4.A record producer vs a catalog item will appear nearly the same for your end users, so I'd say it's mostly a process decision in terms of how you'd like to handle them once they're submitted.
5. Record Producer gives a non-itil user the ability to create things like an Incident, Change, basically anything but a Request from a custom front end you deliver via the Service Catalog/Portal.
Please mark as Correct Answer and Helpful, if applicable.
Thank You!
Abhishek Gardade
12-25-2019 10:08 PM
Hi Anand,
A record producer will be used in your scenario.
A record producer is a specific type of catalog item that allows end users to create task-based records, such as incident records, from the service catalog.
Use record producers to provide a better end-user experience instead of using the regular task-based form for creating records. The look and feel of a record producer is similar to that of a catalog item. But the record producer generates a task record such as incident, instead of a requested item.
You can create a record producer for tables and database views that are in the same scope as the record producer. You can also create a record producer for tables that allow create access from applications in other scopes.
Check this link for an example to create a record producer on change_request table.
wiki.servicenow.com/index.php?title=Creating_a_Record_Producer_to_Request_a_Change#gsc.tab=0
If my answer worthy kindly mark as helpful and correct.
Ajim
01-31-2025 10:31 AM
Hello Anand,
The difference between Record Producers and Catalog Items in ServiceNow comes down to their intended use and the way they interact with records in the system:
Record Producer
- A type of catalog item specifically designed to create records in tables outside of the standard Request table (sc_request).
- Typically used for creating records in task-based tables like incident, problem, change, or even custom tables.
- When a user submits a record producer, it bypasses the request fulfillment process (i.e., no sc_request, sc_task, or sc_req_item records are created). Instead, it directly creates a record in the target table.
- Ideal for scenarios where you want users to submit a request or create a record without a structured approval or fulfillment process.
Example Use Case: A "Report an Issue" record producer that creates an Incident record directly in the incident table.
Catalog Item
- A standard Service Catalog offering used in request fulfillment.
- When a catalog item is ordered, it generates:
- A Request (sc_request)
- One or more Requested Items (sc_req_item)
- One or more Catalog Tasks (sc_task)
- These items typically involve workflow automation, approvals, and fulfillment processes before completion.
- Commonly used for ordering hardware, software, access requests, or any structured service request.
Example Use Case: A "New Laptop Request" catalog item that triggers an approval workflow and fulfillment tasks before delivering the laptop.
Key Differences
Feature Record Producer Catalog Item
| Purpose | Creates records in any table | Initiates a structured request fulfillment process |
| Creates Request (sc_request)? | ❌ No | ✅ Yes |
| Creates Requested Items (sc_req_item)? | ❌ No | ✅ Yes |
| Creates Tasks (sc_task)? | ❌ No | ✅ Often (if workflow is attached) |
| Approval Workflow | ❌ Typically not used | ✅ Can have approvals |
| Use Case | Direct record creation (e.g., submitting an issue) | Structured service request (e.g., ordering a laptop) |
Thank You!
Florin Benciu
SST Romania.
