Display Help text under checkbox and set it as not always expanded.
PriyaRaj
I am having a requirement to add a help text under a checkbox field in service catalog. The help text option is not coming up for this field. So, I tried doing the same with showfieldmsg but it is coming up as always expanded. How we can fix this, if the user clicks on more info then only the field msg should appear. It should not be always expanded via script.
Kindly help and thanks in advance!!
Saurav11
De-activate the UI policy "Show/Hid Annotations tab" so Annotation tab will display on platform view with help text for checkbox variable
https://yourinstancename-now.com/now/nav/ui/classic/params/target/sys_ui_policy.do%3Fsys_id%3D809feb...
The you can add the show help directly in checkbox variable as well.
Please check the below support article for the same:-
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0712308
Please mark my answer as correct based on Impact.
