Display Multi row variable set columns in notification
Chenab Khanna
Hi
I have a multi row variable set and there is data in the columns. Does anyone have any idea how can i display that table in notification?
I am using email script wherein i am calling the variables via GlideAppVariablePoolQuestionSet, but unable to get the multi row variable?
Is there any way possible?
or may be some columns in it?
@Chenab Khanna
that's correct.
If you are using any reference variable inside MRVS you will get sys_id and not the display value
you will have to query the reference table with that sys_id and get the display value.
Something like this
Updated in bold is the change
(function runMailScript( /* GlideRecord */ current, /* TemplatePrinter */ template,
                                            /* Optional EmailOutbound */
                                            email, /* Optional GlideRecord */ email_action,
                                            event) {
    var req_id = current.sysapproval;
    template.print('<p><span style="font-family: arial, helvetica, sans-serif; font-size: 10pt;"><strong>' + req_id.number + '</strong>');
    template.print(' : ' + req_id.short_description + ' <br /> <br />');
    //print variables
    var set = new GlideappVariablePoolQuestionSet();
    set.setRequestID(req_id);
    set.load();
    var vs = set.getFlatQuestions();
    if (vs.size() > 0) {
        template.print('<strong>Request Item Variables:</strong><br /><br />');
        for (var i = 0; i < vs.size(); i++) {
            var show_line = 'true';
            if (vs.get(i).getLabel() == 'Line Manager Approval required?' || vs.get(i).getLabel() == 'Line Manager') {
                show_line = 'false';
            if (vs.get(i).getLabel() == 'AD Action') {
                var ritmGR = new GlideRecord('sc_req_item');
                if (ritmGR.get(req_id)) {
                    gs.log("Entered into the IF conditon of AD Action");
                    template.print('<table>');
                    template.print('<th>Name</th><th>Email</th><th>Department</th>');
                    var mrvs = ritmGR.variables.ad_management_multirow; //check and put correct name
                    var rowCount = mrvs.getRowCount();
                    gs.log("print mrvs " + mrvs);
                    gs.log("Row count of MRVS length " + rowCount);
                    for (var s = 0; s < rowCount; s++) {
                        var row = mvrs.getRow(s);
                        var displayDepartmentValue = getActualValue('cmn_department', row.user_department);
                        template.print("<tr>");
                        template.print("<td><center>" + row.user_name + "</center></td>"); //check fieldname
                        template.print("<td><left>" + row.user_email + "</left></td>"); //check fieldname
                        template.print("<td><left>" + displayDepartmentValue + "</left></td>"); //check fieldname
                        template.print("</tr>");
                    template.print('</table>');
            if (vs.get(i).getLabel() != '' && vs.get(i).getLabel() != null && show_line == 'true' && vs.get(i).getDisplayValue() != '' && vs.get(i).getLabel() != 'AD Action') {
                template.space(4);
                template.print('<strong>' + vs.get(i).getLabel() + "</strong>: " + vs.get(i).getDisplayValue() + "<br />");
    function getActualValue(table, value){
        var gr = new GlideRecord(table);
        gr.addQuery("sys_id", value);
        if (gr.next()) {
            return gr.getDisplayValue();
})(current, template, email, email_action, event);
21 REPLIES 21
@Chenab Khanna
that's correct.
Something like this
                                            event) {
    //print variables
    set.load();
                template.space(4);
        if (gr.next()) {
This worked. Thanks alot for your help
@Chenab Khanna
Glad to know this.
Please mark my response as correct and helpful to close the thread so that others can be benefited by this.
asifnoor
Hi
I assume MRVS is linked to some record. So instead of querying GlideAppVariablePoolQuestionSet, you can use current.variables and can parse them in the mail script.
Can you share your mail script which you have done. I can customize and let you know.
I am going to create new email script for this. And yes, the MRVS is coming in a tabular format in RITM. I just want it display in notification.
Could you please let me know how can do that?
