Display Reference Variable as a drop-down list
alexcolbert
Hi Community,
I am trying to display a Reference variable as a drop down list.
I have added "ref_auto_completer=AJAXReferenceChoice" to the variable attributes but it still shows the magnifying glass:
Am i missing something obvious?
(note: I've tried using the lookup select box type, but it doesn't seem to offer the same functionality as a reference type)
Thanks!
Alex
Yeah, there is no dot walking in lookup select box.
If there is just one variable that you need from the user, like just the email then you can make use of the '' and get the value.
ggg
Giga Guru
On the Choice List Specification tab for the 'Choice' field you must select 'Dropdown with --None--'
