Distinct or unique values on reference field / lookup
Nik Amy
Hey all
On a form i have created a reference field which points to a custom table and this table has NO UNIQUE key.
So upon clicking the lookup icon, it should display only unique or distinct values like below it should show only 1200 and 1300.
      VenIDName
1200ABC
1300XYZ
1200JKL
I have made use of reference qualifier and wrote a code like
vendorIdList = arrayUtil.unique(vendorIdList);
This is working, but since the table has some thousands of records, its taking very long time to display the unique values.
Any other method to achieve this quickly.
TIA
17 REPLIES 17
Yes Berny. Its checked only
And if that still doesn't work, can you reproduce this in any demo instance?
Replace
return 'sys_idIN'+ticket_id+'';
With
return 'sys_idIN'+ticket_id.toString();
And
return 'sys_idIN'+'***'; //
With
return ''; //
Hi Kalai,
Still returning null values.
What i found was like its not returning values when GlideAggregate is used.
when i replaced
  ticket_id.push(ticket_list.sys_id+'');
with
  ticket_id.push(u_ven_id.sys_id+'');
it will atleast populate the values (but not unique)
Any other idea
Nikh
Use toString() whenever you are pushing value into array. Can you change that?
