Do we have options to cancel a problem ticket?
Sofiya Perumal
Hi experts,
How to cancel a problem ticket? Is it possible to cancel it without adding any scripts from back end? Please suggest a solution for this.
Sofiya
Vaishnavi Lathk
there is the OOTB UI Action "Cancel" on the problem table.
Basically, that UI Action sets the state to "Closed" and forces the user to enter a "Canceled reason", which is basically the close notes field but relabeled.
You can modify the UI Action so that it closes all related open Problem Tasks + send a note to all related incidents
Vaishnavi Lathkar
Harish KM
HI there is OOB Cancel UI action on Problem table. you may look for the condition when we can cancel the problem..
Harish
Thanks for looking into the issue Harish! I have created a UI action already but I don't want cancelled option in the status field of the ticket. It must be hided. Is there any options to achieve it?
Sofiya
RIght click on state field--show choice list--find the choice list of cancelled for problem..you have field called "Inactive" change it to true. This will hide the state.
Harish
Aman Kumar S
Hey,
Cancel and Mark Duplicate OOB UI action helps you achieve this and its available to problem coordinator role.
Feel free to mark correct, If I answered your query.
Will be helpful for future visitors looking for similar questions 🙂
Best Regards
Aman Kumar
