Do we have options to cancel a problem ticket?
Sofiya Perumal
Hi experts,
How to cancel a problem ticket? Is it possible to cancel it without adding any scripts from back end? Please suggest a solution for this.
Sofiya
Vaishnavi Lathk
there is the OOTB UI Action "Cancel" on the problem table.
Basically, that UI Action sets the state to "Closed" and forces the user to enter a "Canceled reason", which is basically the close notes field but relabeled.
You can modify the UI Action so that it closes all related open Problem Tasks + send a note to all related incidents
Vaishnavi Lathkar
Thanks for looking into the issue Aman! I have created a UI action already but I don't want cancelled option in the status field of the ticket. It must be hided. Is there any options to achieve it?
Sofiya
You can hide that option using onload client script:
g_form.removeOption("state",7);// check the field name and cancelled backend value
Best Regards
Aman Kumar
Hey @Sofiya Perumal ,
Didn't hear back on this.
Is your issue resolved? If yes, feel free to mark helpful/correct, so it will be helpful for others looking for similar query.
You have marked the response as helpful but not correct?
Best Regards
Aman Kumar
Vaishnavi Lathk
Vaishnavi Lathkar
