Doer & Checker Validation
mounika36
Giga Contributor
In order to address an audit violation, my Services needs to validate that the Implement Change (Doer) & the Check Implementation (Checker) tasks are not assigned to the same person. The assignment group can be the same, but the Assigned to, should be a different person
Ok, so I am hoping there is some Task Type for that validation task as well based on which here is the script.
Client script on Change of Assignee
var assignee = g_form.getValue('assigned_to');
var id = g_form.getValue('change_request');
var ctask_type = g_form.getValue('change_task_type');
if(ctask_type == 'Implementation')
var Ajax = new GlideAjax("checkUser");
Ajax.addParam("sysparm_name","validateChecker");
Ajax.addParam("sysparm_user",assignee);
Ajax.addParam("sysparm_id",id);
Ajax.getXML(getVal);
if(ctask_type == '<ctask type of validation>')
var Ajax1 = new GlideAjax("checkUser");
Ajax1.addParam("sysparm_name","validateImplementer");
Ajax1.addParam("sysparm_user",assignee);
Ajax1.addParam("sysparm_id",id);
Ajax1.getXML(getVal1);
function getVal(response) {
var answer = response.responseXML.documentElement.getAttribute('answer');
if(answer == "true")
alert('Checker cannot be same as the Implementer.');
g_form.setValue('assigned_to',"");
function getVal1(response) {
var answer1 = response.responseXML.documentElement.getAttribute('answer');
if(answer1 == "true")
alert('Implementer cannot be same as the Checker.');
Script Include:
Please write similar function for validateImplementer.
Hi Jyothsna,
Did provided solution work for you?
