encryption of catalog item field post submission on portal and RITM
dhivyal94299399
I have requirement, where i need to encrypt or mask the address field in the catalog form, post submission of the user in the portal and RITM.
That shipping address is populated to the catalog task of the description, where i need to encrypt.
Tanushree Maiti
Hi @dhivyal94299399
There are couple of ways to do it. like
Option1 :  Create a Masked type Variable for your requirement .
Refer: Masked
Option2: Using Flow
  • In your flow, after the "Get Catalog Variables" action, use a "Script" step.
  • Use Javascript to replace the address text with Masked before it populates the description
Refer: KB0826510 Not able to unmask masked variable in flow designer
Ankur Bawiskar
@dhivyal94299399
share screenshots what encryption you want?
@Ankur Bawiskar
where the shipping address is the field in the catalog item. Once the user submit the form, the address field value is populated to the catalog task description field.
I want the address in the description should be visible to the assigned to user of the task,
And another case is, we can able to see the catalog variable submitted in the RITM, i need to mask the shipping address
