Fetching values from URL - Agent Workspace
ramwons
Kilo Expert
I have to fetch values from the URL (sc_req_item & sysID next to it) and set it in Table field "source_table" & Document ID field "source_record"  on the form respectively.
Sample URL as follows:
https://xyzdev.service-now.com/now/workspace/agent/record/sc_req_item/7f93e37b1ba33f0020c8fddacd4bcb...
I'm tried following method  but not sure how to use it exactly.. I used the same method for UI16 and it worked as expected
var gURL = new GlideURL();
gURL.setFromCurrent();
Hi Ram,
I doubt this can be achieved
Hi @Ankur Bawiskar ,
I changed the script like below. I'm getting values in the variable but the values are not getting set to the form.
Now, I checked the Client script written for UI16 which is also stopped working.. V strange behavior as it worked yesterday and not now.
 var url = top.location.href;
    alert(url);
    var ritmTab = "sc_req_item";
    if (url.includes(RITMstring)) {
        alert("sc_req_item is in URL");
        var indexOfRITM = url.indexOf(ritmTab);
        var indexOfSysIDstart = indexOfRITM + ritmTab.length + 1; // index of sc_req_item substring start + lenght of sc_req_item substring + 1 (lenght of "/") that means this is index of first char after "...sc_req_item/"
        var sysIDlenght = 32; // sysID is always 32 chars long
        var ritmID = url.substring(indexOfSysIDstart, indexOfSysIDstart + sysIDlenght);
        g_form.setValue("source_record", ritmID);
        g_form.setValue("source_table", ritmTab);
        g_form.setValue("u_escalation_type", "4");
        alert(ritmID);
        alert("sc_req_item is NOT in URL");
Best Regards,
Ram
