Fetching Variable Values from Multi Row Variable Set Using mail script
We have a requirement to retrieve variable value from multi row variable set in Email notification.
Notification script is attached below
Currently I am able to retrieve all variable values into email  notification except multi row variable
When I tried to add in the email script I am getting value as undefined. So please help me out
Sanketh
Ankur Bawiskar
check this link and enhance as per your requirement
How to Display Multi Row Variable set (MRVS) data in a notification
Ankur Bawiskar
Ankur Bawiskar
@Sanketh Ayyapusetty
if your notification is on RITM table then use this
var mrvs;
mrvs = current.variables.your_mrvs_name;//mention your mrvs internal name here
var rowCount = mrvs.getRowCount();
template.print("<table>");
for (var i = 0; i < rowCount; i++) {
	var row = mrvs.getRow(i);
        template.print("<tr>");
        template.print("<td>"+row.your_variable_name1+"</td>"); //mention your variable name
        template.print("<td>"+row.your_variable_name2+"</td>"); //mention your variable name
        template.print("<td>"+row.your_variable_name3+"</td>"); //mention your variable name
        template.print("</tr>");
template.print("</table>");
If your notification is on approval table then use this
var mrvs;
mrvs = current.sysapproval.variables.your_mrvs_name;//mention your mrvs internal name here
Thank you.
Hi Ankur,
I have a requirement of updating values of MRVS variables in to related fields in sc_task table.
Actually My MRVS is attaching to my task at the time of task create (I have UI policy to hide from RITM and portal) and I want once values of the MRVS variables are updated  by an agent, it need to updates to sc_task table.
I have tried with BR as below
var mrvs;
var taskGR = new GlideRecord('sc_task');
if (taskGR.get(current.sys_id)) {
mrvs = taskGR.variables.u_demand_management_relese_details; // Internal Name of MRVS
gs.print(mrvs);
current.buid_end_date=row.u_actual_build_end_date;
current.status=row.u_status;
Request to suggest on this.
Samarendra Nayak
