Field Label
tushar_ghadage
Hi Everyone,
we have implemented a field on RITM level but when end user changes the language of the instance to Norwegian from setting in the profile section, end user sees the field in English only which she should see in her Norwegian language.
I am not sure how should do this can anyone help??
Thanks!!
@tushar_ghadage
Glad to know.
Please mark my below response as correct so that it helps other members
16 REPLIES 16
yes it worked . thankss
@tushar_ghadage
Glad to know.
shun6
@tushar_ghadage
I assume that value of Element field is wrong.
You need to set the clumn name instead of column label.
For example, element should be "request_to" not "Request to".
Thanks.
Hi @shun6 ,
yes i have mentioned the column name as over_time ..
but  its not reflecting back
shun6
@tushar_ghadage
Another thing to check might be whether the language code is correct ...
I searched for 'Norwegian' within BCP 47(can be accessed via below docs) and several code was found.
Field Label table
