Field randomly clearing on Save
paul_mcnamara
Giga Expert
Version: Dublin Patch 3
Table: u_case_task
Extends: u_case
Extends: Task
Field: u_authority_level on Table u_case and inherited on u_case_task
When I hit New Case Task and populate the u_authority_level field and hit save approximately 75% of the time the field is cleared.   The field is not cleared immediately as it is used to add a Skill to the Case and that happens successfully.   This only started happening after we upgraded to Patch 3.   Our instance that is not patched yet does not have this issue.
I have gone so far as disabling every Business Rule, Client Script, UI Policy, Script include that touches the Case Task table and the issue persists.       If anyone has some ideas of things to look at or things to do I would be interested in a different perspective!
Thanks!
16 REPLIES 16
Hi, have you got the solution for this issue. I am facing a similar one now.
THanks!
Ram118
Mega Guru
HI,
I am facing the similar Issue now. did you found any solution to fix this kind of Issue.  If so, please do let me know.
Thanks in advance..
