Field values are not updated when creating change from template
Saranya2
-> When trying to create a change request from standard change template, the fields are auto populated from template.
-> While insertion when trying to change any field from template, it is not getting updated. But when trying to update the field it is updated.
-> I found OOTB before insert/update BR "Restrict fields from Standard Change", In the script, while insertion it is applying template values (if the fields are defined from standard change properties)  as below.
-> But I am trying to change the value which are not defined in below property. but still it is applying template value while inserting record.
Hi @Saranya2 ,
If you are using the templates it will apply after insertion. So you can update the fields once it is created.
PavanK960672992
Mega Patron
Hi @Saranya2 ,
If my response helps you to resolve the issue close the question by Accepting solution and hit thumb icon. From Correct answers others will get benefited in future.
