Filter reference field based on another reference field in catalog item
Bindhu1
Hi , Kindly help me to achieve this .
I have two reference field ,
1st field refers to u_building (which stores locations) and
2nd field refers to  u_cmdb_ci_server_virtual (stores VMs)
Based on location selected is first variable , 2nd variable should give VMs of that location
Sample record of u_cmdb_ci_server_virtual (stores VMs)  with location refers to u_building (which stores locations)
Sandeep Rajput
@Bindhu1 You should use the following reference qualifier on the second variable.Screenshot 2024-02-14 at 7.15.38 PM.png
javascript&colon;'location='+current.variables.<first_variable_name>
Here replace <first_variable_name> with name of the first variable.
Hope this helps.
Sandeep Rajput
Hope this helps.
Thanks for replying , this filter giving all record, not sure where i am going wrong .tried with different filter
javascript&colon;'location='+current.variables.select_the_data_centre
javascript&colon;'location='+current.variables.select_the_data_centre.u_building_name
Hi @Sandeep Rajput , Thanks for your help.
This is working with below filter
javascript&colon;"location="+current.variables.select_the_data_centre
Dr Atul G- LNG
Hi @Bindhu1
Dud you try with depend way like we have category and sub category?
