06-18-2025 03:40 AM
Hi Team,
Can someone help to update 500 ritm records fix script
A fix script needs to update the RITM records to:
Approval : Rejected
State Closed incomplete
Stage Closed incomplete
06-19-2025 02:58 AM
you can enhance it further.
// give correct query, correct state, stage value to compare
gr.addQuery('state', '!=', 4); // Only update if not already closed incomplete
gr.setLimit(500); // Limit to 500 records
while (gr.next()) {
gr.approval = 'rejected';
gr.state = 4; // Closed Incomplete
gr.stage = 'Closed Incomplete';
gr.update();
var gr = new GlideRecord("sysapproval_approver");
gr.addQuery("sysapproval", gr.getUniqueValue());
gr.addQuery("state", "requested");
while (gr.next()) {
gr.state = 'rejected';
gr.comments = 'Auto rejected as RITM is closed';
gr.update();
07-03-2025 05:54 PM
Seems you accepted a solution earlier. that script proposed by Ankur needs a change to process all sc_req_item records and related sysapproval_approver records:
while (gr.next()) {
gs.info('update req item; ' + gr.number);
gr.setWorkflow(false);
// gr.update();
var grsa = new GlideRecord("sysapproval_approver");
grsa.addQuery("sysapproval", gr.getUniqueValue());
grsa.addQuery("state", "requested");
grsa.query();
while (grsa.next()) {
grsa.state = 'rejected';
grsa.comments = 'Auto rejected as RITM is closed';
grsa.info('update approval.');
grsa.setWorkflow(false);
// grsa.update();
}un-comment the 'update()' lines after testing. Notifications should cease from the updates.
07-03-2025 06:26 PM
Thank you, in my case i need change a list of record like, ex: [RITMxxxxx,RITMxxxxx] this is a point that i have a little doubt.
07-04-2025 11:29 AM
I suggest you start a new thread, as a (corrected) solution is here for what it seems you originally asked for. And be explicit in what your goal is.
