flow design - Catalog MRVS
priyakakarla20
Hello Experts,
I have a catalog item in ServiceNow.
In that, I have a Multi Row Variable Set (MRVS) with variables Environment and Domain.
  • Domain choices: Internal, External
  • Environment choices: Prod, Public, Semi-Pub
I created a Flow Designer flow. After the catalog item is triggered, MRVS variables are not directly accessible, so I used a For Each loop to process the rows.
Based on the Environment and Domain conditions, I am creating SCTasks. This part is working.
However, the issue is:
In the MRVS, I can add multiple rows (e.g., both Internal and External conditions), but in the flow, only one condition/task is being generated. The remaining rows are not being processed as expected.
Thank you,
Priya.
11 REPLIES 11
Vishal Jaswal
Tera Sage
Hello @priyakakarla20
Here is a dummy flow which will help you to achieve this:
Hi Vishal,
Thank you for your replay.
I tried in PDI, but it is only creating the task for only first line of the MRVS,
Please find the images.
Thank you,
Priya.
Hi  @Vishal Jaswal ,
In the log only first, row is captured .
Hi  @priyakakarla20 ,
you have to click on and switch from 1 to 2 to see logs related to the second task (see screenshot).
Hope this help.
