Flow Design create a problem Ticket
Subhrajit Swain
Create a Problem ticket from Incident if an incident has been created 10 times for the same CI.
OlaN
Tera Sage
I would suggest that you create a Flow that does this for you.
Example below
Subhrajit Swain
Thank you for help
the problem I am facing with your solution is that I am not available to find count pill can please further help me
Make sure you use
"Look up records" action (will find one or more records)
not the
"Look up record" action (will find only one record)
