‎02-15-2021 06:08 AM
Hello!
I am trying to get approval from the Product Owner of each software selected in a list collector. The list collector is link to the Software Model and the For Each action allows me to use the List but when I try to do a Look Up Record to try and get the Product owner, the data pill from the For Each action is greyed out.
Where have I gone wrong? I need to do this for 6 different list collector fields in the same manner but on different tables.
Any help would be greatly appreciated!
Service Catalog
‎02-15-2021 06:12 AM
refer my blog for converting the string into array of string
if that helps please mark it helpful and also bookmark it
Using list collector in Flow Designer 'For Each loop' by converting string into array of string
‎04-20-2022 03:32 PM
Thank you for the amazing post. It surely did help. However, I'm stuck with the same issue. It will not recognize the pill as an array. I set the output on action to Array.Object. That doesn't work either. I'm on San Diego release.
The output is grayed out on the flow.
What is it that I'm doing wrong?
Thank you in advance.
‎05-02-2022 11:43 AM
‎02-15-2021 06:38 AM
I hope you must have marked the blog as helpful and also bookmarked it
‎10-11-2023 04:10 AM
Still it is not working for me, i am unable to select the variable, see the screenshot
