10-11-2021 10:21 PM
I have created flow designer for one catalog item and using subflow in that .
I am passing trigger requested item as input in subflow.
How to use those input variables in catalog task description script. I want to use RITM's sys_id in subflow script.
can someone please help.
Sonali j
Service Catalog
10-12-2021 01:30 AM
So can you share a bit of what you are scripting? Anyway, without knowing that, you do have a subflow input "ritm", you can access that in script using:
var ritm_sysid = fd_data.subflow_inputs.ritm
Kind regards,
Mark
2020, 2021 ServiceNow Community MVP
2020, 2021 ServiceNow Developer MVP
10-12-2021 12:19 AM
What's the reason for wanting to use the script field? As you can drag and drop or use the data pill.
Scripting is certainly possible, though why?
Kind regards,
Mark
10-12-2021 12:47 AM
In description part of catalog task we need variables values to be populated.
10-12-2021 01:30 AM
Kind regards,
Mark
01-16-2024 03:58 AM
the subflow_inputs variable doesn't comeup in auto-suggestion. Is that true?
10-12-2021 12:56 AM
since you want to set catalog task description with variable value; you can use the inline script in f(x) for task description field
No need to create subflow for this
As mentioned by Mark you can drag and drop; but here is an Script example in f(x) for Description field
You can enhance it as per your requirement.
var sysId = fd_data.trigger.current.sys_id;
gr.addQuery('sys_id', sysId);
if(gr.next()){
return "My Variable Value " + gr.variables.variableName; // give the variable name here
