Flow designer not allow to save and thrown out error
sukran
While saving the flow its thrown an error saying
"Unknown error occurred while processing request , check logs to get more information"
sukran
Found the solution
Issue causing after upgrade to vancouver .. The flow trigger condition previous versions UI , can able to select directly as Service Catalog :
But In Vancouver we have to choose Trigger condition as Application -> ServiceCatalog "
The UI selection is different in vancouver which causing existing flow for save
Sainath N
@sukran : please check if the below HI article helps.
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB1219673
Please mark this as correct answer and helpful if it resolved, or mark this helpful if this help you to reach towards solution.
Dr Atul - LNG
sukran
Found the solution
