Flow designer not to update empty input from variable
KeerthiChaK
I am trying to update a record from Flow designer, I want to skip the update if the variable input is empty. Please suggest how I can skip a specific filed update if the variable input is empty.
Thanks in advance.
Marcin20
Giga Guru
I propose to add the if Flow Logic before the update Flow Action and execute this action only when the if Flow Logic condition is true.
Best Regards,
Marcin
If my answer helped you in any way, please mark this answer as helpful and correct.
Thank you for the response!!
I do have eight fields like that, and we cannot add if logic for each one 😞
Could you please suggest any other option that we can utilize in flow designer?
You can have one If logic with eight conditions. It would be easiest to maintain.
Such as:
Field 1 is not   AND
Field 2 is not   AND
Field 3 is not    AND  [..]
Best Regards,
Marcin
Brian2046
just script it
var gr = inputs.someRecord;
if(inputs.var1){
    gr.var1 = inputs.var1;
if(inputs.var2){
    gr.var2 = inputs.var2;
try{
   gr.update();
catch(ex){
   //error handler
