Flow Designer to check for all parallel sc_task state if anyone updated 'Closed Completed'
Shridhar1
For RITM, if parallel sc_tasks are generated (example 4 tasks) via flow. If anyone of sc_task is close completed how can we monitor this using flow designer. As we need to perform other actions once anyone of sc_task is close completed
we don't know number of parallel sc_task generated for catalog item, sc_task are  generated via subflow.
This RITM flow is generic flow configured for multiple catalog items created via catalog builder.
We have an option using BR, but requirement is to fulfill it via flow itself
Thank you
Hello Kailas,
Yes this can be done using BR, but we are looking for solution via flow itself
Thank you
Hi Shridhar,
This is just logic, you can implement it in FLOW as well.
Hope this helps.
If my answer resolves your issue, please mark my answer as ✅ Correct & Helpful based on the validations.
Thank You!
Kailash
Shridhar1
We couldnt able achieve expected output using the same flow
Finally configured BR for this issue.
Thank you everyone for the help
