Flow designer update trigger conditions
04-09-2026 08:17 PM
Hello Team,
I have one outbound integration setup with one third-party tool.
Once a incident is created(and assignment group is x) the incident needs to be created on the third-party system .I have created a flow and got the response and did set the number into correlation id field successfully.
Now i want update as well if my incident gets updated then which value got updated accordingly dynamically i need to build the payload.(Also integration for this not trigger for all the fields update only some fields like state additional comments etc.)
Now if i created a update flow one new then what conditions i should keep so that it wont go on loop and also i need to find which field/fields got updated if they need to be updated in the third party system then only i will trigger the integration otherwise not.
Also if both of these can be done in one flow or two flows needed i need help on the conditions of the flow what i should put so it won't go on loop and it should do the job as needed.
@Ankur Bawiskar any suggestions?
04-10-2026 01:04 AM
how would you know which field got updated when? you can check sys_audit table for this
