Flow Designer - Wait for Condition not working
05-09-2023 10:14 AM
I have created a flow designer. I need to wait for 5 minutes after the state is changed from On-boarding to Provisioning and i have added a wait for condition on the flow designer to wait for 5 minutes when the state changes to Provisioning which fails to wait for 5 minutes and the flow is completed without waiting.
Below is the flow:
Can anyone please help me achieve this?
Thanks.
05-09-2023 10:44 AM
@Hari1 The way you have configured the Wait for condition to wait for 5 minutes by configuring the duration field is not going to work as the purpose of that duration field is different.
According to the docs.
Duration field will only be used when Enable Timeout check box is checked. Also, timeout is usually used to bring the wait for condition to closure after a certain duration so that the flow doesn't wait perpetually.
In order to make a flow wait instead use the Wait for duration flow logic as follows.
Here is the documentation for your reference https://docs.servicenow.com/en-US/bundle/rome-servicenow-platform/page/administer/flow-designer/conc...
Please mark my answer helpful and correct if it manages to fulfil your requirement.
