Flow Designer - Wait for condition
Akshay Jadhav1
Hello All,
As seen in the screenshot below, we used the wait for condition on a checkbox available in the RITM. However, the problem is, It takes about an hour to be satisfied after checking the checkbox. Does anyone have any clue what changes are required to make it work properly?
Thank you
Sohail Khilji
Hi @Akshay Jadhav1,
What does this flow execution return in log while running ?
did you use ''get catalog varaible'' action before the wait for condition ?  if not use it like below and then use wait for condition refering variables from ''get catalog variable'' action.
☑️ Please mark responses as HELPFUL or ACCEPT SOLUTION to assist future users in finding the right solution....
LinkedIn - Lets Connect
