Flow issue
joshmorris
Can anyone help, why is there only 1 catalog task that gets created when approved? It clearly shows 3
4 ACCEPTED SOLUTIONS
Shruti
It looks like a sequential task creation. Once catalog task 1 is closed , catalog task 2 will be created
glideFather
Hi @joshmorris
you have the 3 tasks in the sequence, try to close the 1st task and you will see if the second will be created.. then close it and third should be created...
you should change the branch to do it in parallel
Chaitanya ILCR
Giga Patron
HI @joshmorris ,
1. you can use Do the following in Parallel flow logic and create tasks parallelly
or
you can uncheck wait check box on 1st 2 catalog tasks
and  put an wait for condition for all the tasks to get closed after last task
Chaitanya
Ankur Bawiskar
@joshmorris
As per image they are sequential but please check your flow config for that step
a) if Wait checkbox is checked it means 2nd one will trigger on closure of 1st and same for 3rd one
b) if it's unchecked then all 3 should get created in parallel.
Shruti
glideFather
Hi @joshmorris
Chaitanya ILCR
Giga Patron
HI @joshmorris ,
or
Chaitanya
Ankur Bawiskar
@joshmorris
