07-27-2023 08:23 AM - edited 07-27-2023 08:23 AM
Since upgrade to Utah, all our attachments are being encrypted. In Tokyo and before there was a checkbox here to choose to encrypt. That is now gone and none is not the default option.
ServiceNow support says this is OOB, but I can't believe this was intended.
#encryption
#crypto
#attachments
- 20,978 Views
07-27-2023 12:15 PM - edited 07-27-2023 01:51 PM
HI told me to post on community and this was an OOB setting. I spent another 3 hours on it and figured this out --
update the optional_attachment_encrypt UI macro.
OOB config:
Updated:
You also need to comment out these lines:
01-01-2024 11:53 AM
I have this same issue on my instance but when I follow the link to the knowledge article, I get a message saying my role doesn't grant me access to the article. Now I can take that up with SN and my SN account manager but can you list the pertinent points from the article?
10-13-2025 10:31 AM
1. Elevate your role
2. go to encrpt config table (sys_platform_encryption_configuration) and inactivate the table in which you don't want to encrypt
or
create a record with the table in which you don't want the encrypt attachment to happen
3. add this system property if it's not in your system, "com.glide.encryption.enable_attachment_key_ui" and set it to false.
10-31-2024 11:27 AM - edited 10-31-2024 11:28 AM
Hi @Kim Sullivan , I'm on Xanadu in DEV and TEST. Xanadu is the FIRST time we've seen the Encrypt Attachments pop up and we were on Tokyo, then Vancouver and hadn't had this come up. I tried your code change in the optional_attachment_encrypt UI macro and this didn't work for me.
My code looks like this:
Trish
10-13-2025 07:11 AM
Hi @Kim Sullivan ,
Could you please assist with the Yokohama version? I've implemented the scripting changes you recommended, but the images are still being encrypted.
10-13-2025 07:16 AM
Will you post your script so I can confirm? Also, keep in mind, impersonating is not a good tool to test encryption. Its better to use a local user and confirm that way.
