07-27-2023 08:23 AM - edited 07-27-2023 08:23 AM
Since upgrade to Utah, all our attachments are being encrypted. In Tokyo and before there was a checkbox here to choose to encrypt. That is now gone and none is not the default option.
ServiceNow support says this is OOB, but I can't believe this was intended.
#encryption
#crypto
#attachments
- 20,978 Views
07-27-2023 12:15 PM - edited 07-27-2023 01:51 PM
HI told me to post on community and this was an OOB setting. I spent another 3 hours on it and figured this out --
update the optional_attachment_encrypt UI macro.
OOB config:
Updated:
You also need to comment out these lines:
10-13-2025 07:32 AM
@Kim Sullivan attaching UI Macros for you reference.
<div style="display:inline;" aria-hidden="true">
<j:set var="jvar_target_table" value="${RP.getWindowProperties().get('target_table')}" />
<g:evaluate var="jvar_encryption_modules" object="true" jelly="true">
var encryption_modules = gs.getSession().getCryptoModulePickerForTableWithSingleModule(jelly.jvar_target_table).getSysIds();
var encryption_modules_count = encryption_modules.size();
encryption_modules;
</g:evaluate>
<g:evaluate var="jvar_encryption_modules_count">
</g:evaluate>
<g:evaluate var="jvar_current_encryption" jelly="true">
gs.getSession().getCryptoModulePickerForTableWithSingleModule(jelly.jvar_target_table).getCurrent();
</g:evaluate>
<g:evaluate var="jvar_change_encryption_label">
gs.getMessage('Change Encryption Module');
</g:evaluate>
<!-- Show encrypt selector as it doesn't make sense to have encrypt on some tables. -->
<g:evaluate var="jvar_show_encrypt" jelly="true">
var show_encrypt = jelly.jvar_encryption_modules_count > 0;
if (jelly.jvar_target_table == 'sys_email')
show_encrypt = false;
show_encrypt;
</g:evaluate>
</div>
<j:if test="${jvar_show_encrypt}">
<!-- NOTE: jvar_encryption_module_count > 0 -->
<g:evaluate var="jvar_encryption_choices" object="true" jelly="true">
gs.getSession().getCryptoModulePickerForTableWithSingleModule(jelly.jvar_target_table).getChoices().getSelected();
</g:evaluate>
<!-- <g:evaluate var="jvar_current_encryption_module" jelly="true">
</g:evaluate> -->
<div style="margin-top: 20px;">
<input value="${jvar_current_encryption}" id="default_encryption_module" name="default_encryption_module" type="hidden" />
<span>
${gs.getMessage('Encrypt with Module')}:
</span>
<select id="encryption_module" title="${gs.getMessage('Encryption Module')}" onchange="actionOK(event)">
<option value="none">${gs.getMessage('None')}</option>
<g:options choiceList="$[jvar_encryption_choices]" choiceValue="" />
</select>
</div>
<script>
function encryptionSelected(newModule, newLabel) {
gel("default_encryption_module").value = newModule;
gel("sysparm_encryption_context").value = newModule;
updateEncryptionChoice(newModule);
function updateEncryptionChoice(value) {
rememberEncryption(value);
function rememberEncryption(value) {
setPreference('encryption_module', value);
function actionOK(e) {
var moduleSelect = e.target;
var selectedValue = moduleSelect.options[moduleSelect.selectedIndex].value;
if (selectedValue == "")
return false; // you must choose one if you click OK
var selectedLabel = moduleSelect.options[moduleSelect.selectedIndex].innerHTML;
encryptionSelected(selectedValue, selectedLabel);
return true;
// Set the default value on load.
gel("default_encryption_module").value = "$[jvar_current_encryption_module]";
gel("sysparm_encryption_context").value = "$[jvar_current_encryption_module]";
updateEncryptionChoice("$[jvar_current_encryption_module]");
</script>
</j:if>
</j:jelly>
10-13-2025 07:44 AM
Your script looks good. Did you also check your glide.attachment.encrypt_by_default is set to false as recommended by @Jeff Boltz1 ?
10-13-2025 09:15 AM
The property glide.attachment.encrypt_by_default doesn't exist in the system, and when I attempted to create it, I received an error stating: "Not allowing set of unsafe property value: glide.attachment.encrypt_by_default=false."
10-13-2025 09:20 AM
I think others have struggled with that as well. I would suggest opening a HI ticket and seeing if they can assist-- I do believe others in this thread were successful with that method.
08-02-2023 02:56 PM - edited 08-02-2023 02:57 PM
Took me some time to investigate this but at least in the context of Column Level Encryption (CLE), the option to encrypt or not is controlled by a system property 'com.glide.encryption.enable_attachment_key_ui'. True=Give the option, False=Encrypt by default. I tested this out on a Utah instance and seems to toggle the choice as expected.
