Forced encryption on attachments
Kim Sullivan
Since upgrade to Utah, all our attachments are being encrypted.  In Tokyo and before there was a checkbox here to choose to encrypt.  That is now gone and none is not the default option.
ServiceNow support says this is OOB, but I can't believe this was intended.
#encryption
#crypto
#attachments
Kim Sullivan
HI told me to post on community and this was an OOB setting.  I spent another 3 hours on it and figured this out --
update the optional_attachment_encrypt UI macro.
OOB config:
Updated:
You also need to comment out these lines:
34 REPLIES 34
I am facing the same issue only with HR module, all the attachments are getting encypted by default when property com.glide.encryption.enable_attachment_key_ui is false in the syatem.
Modifying macro doesn't help, started happening after washigton upgrade it seems .
checked the Column Level Encryption (CLE), which is active true for HR cases but also unable to deactivate these by our own.
BelenDB
Hi @Kim Sullivan , your solution worked perfectly for me 🙂
Thanks a lot!! I was struggling making the -None- as default option.
Hames_MLH
Hey Kim, I know this post is 3 years old but I wanted to know if you did anything for the newer popup with the two buttons "Upload without Encrypting" and "Upload and Encrypt" that does not exists on your popup.
Hi - our catalog item widget doesn't prompt us for that.  I believe because we are using an older version.
Yeah, that newer version is going to be "fun" to deal with. Thanks for the reply!
