ā01-04-2021 02:03 AM
We have a custom table and we have created 10 form sections for the form in the default view.
Don't know what happened 9 form sections are missing from the form. What could be the reason ?
Those missing form sections are available on the "sys_ui_section" table.
Sirraj
ā01-04-2021 05:40 AM
ā01-04-2021 03:08 AM
if there is nothing it means either form sections were deleted by someone or were not captured initially
ā01-04-2021 03:26 AM
It was there initially, this is a lower instance only (dev). We are working for past 1month with the same form sections. Today sections was not there. I have also checked in the customer updates "sys_update_xml" whether any deletion happened or not. but couldnt find anything.
Where can we check the changes happened to the form recently like deltion of fields and form sections? @Ankur
ā01-04-2021 04:12 AM
Check if you are able to find it in deleted records table
ā01-04-2021 05:29 AM
No records to display.
Guess i should again add the form sections manually to the form which are there in the table.
Sirraj
That's the only way forward
