g_form.setValue not working on ServicePortal
RohanBathla
I am using below script to populate a variable on submit of the catalog item. The script is working fine on desktop from Service Catalog but it is not working on Portal. The setValue is not working on portal alerts are generated on portal as well.
function onSubmit() {
var mylist = g_form.getValue('user_s_to_be_created');
var answer = '';
var myarray = mylist.split(',');
for (var i =0; i< myarray.length; i++)
var getuser = new GlideRecord('sys_user');
getuser.addQuery('sys_id',myarray[i]);
getuser.query();
if(getuser.next()){
alert(getuser.user_name);
answer=getuser.user_name +","+ answer;
alert(answer);
g_form.setValue("user_s_amei", answer);
Thanks Adrian. Let me try this and i will let you know if it worked.
