Get the Catalog variables using Catalog Task
ersureshbe
Hi Guys,
I'm using below script to get the variables are associated with RITM and Task.  The code is providing the result of more than one catalog variables but not providing the associated catalog task numbers. Can you help how to get the mentioned below output? I'm seeing the error is part of  taskInfo['Variables'] = varList;  and  return taskInfo;. Can you help to resolve?
 var taskInfo = {};
    var varList = [];
    var grTask = new GlideRecord('sc_task');
    grTask.addQuery('state', '8');
//    grTask.addQuery('assignment_group', '2d4ac16d1bb159106ece2fc5604bcb26');
    grTask.query();
    while (grTask.next()) {
        taskInfo = {
            'Task_Number': grTask.number.toString(),
            'Service_Request': grTask.request.number.toString(),
            'RITM_Number': grTask.request_item.getDisplayValue(),
            'Short_Description': grTask.short_description.toString(),
            'Description':grTask.description.toString(),
            'State':grTask.state.getDisplayValue().toString(),
            //'item': grTask.cat_item.name.toString(),
            'Business_Justification':grTask.request.special_instructions.toString(),
            'Requested_For': grTask.request_item.request.requested_for.getDisplayValue()
        var grVar = new GlideRecord('sc_item_option_mtom');
        grVar.addQuery('request_item', grTask.request_item);
        grVar.query();
       // while (grVar.hasNext()) {
            while (grVar.next()) {
                var fieldName = grVar.sc_item_option.item_option_new.name.toString();
                //var type = grVar.sc_item_option.item_option_new.type.toString();
                var value = grVar.sc_item_option.value.toString();
                varList.push({
                    'Variable_Name': fieldName,
                   // 'type': type,
                    'Variable_Value': value
            //return taskInfo;
        //return taskInfo;
    return taskInfo;
})(request, response);
Expected Result:
"result": {
    "Task_Number": "SCTASK0253304",
    "Service_Request": "REQ0151698",
    "RITM_Number": "RITM0179353",
    "Short_Description": "Test1",
    "Description": "",
    "State": "Assigned",
    "Business_Justification": "test",
    "Requested_For": "Pankaj Binwal",
    "Variables": [
        "Variable_Name": "refUserID",
        "Variable_Value": ""
    "Task_Number": "SCTASK0253305",
    "Service_Request": "REQ0151699",
    "RITM_Number": "RITM0179354",
    "Short_Description": "Test2",
    "Description": "",
    "Variables": [
Suresh.
@Suresh Loganathan
Try using this.
var taskInfo = [];
grTask.query();
    var temp = {};
    temp.Task_Number = grTask.number.toString();
    temp.Service_Request = grTask.request.number.toString();
    temp.RITM_Number = grTask.request_item.getDisplayValue();
    temp.Short_Description = grTask.short_description.toString();
    temp.Description = grTask.description.toString();
    temp.State = grTask.state.getDisplayValue().toString();
    //temp.item = grTask.cat_item.name.toString();
    temp.Business_Justification = grTask.request.special_instructions.toString();
    temp.Requested_For = grTask.request_item.request.requested_for.getDisplayValue();
    grVar.query();
	var varArray = [];
    // if (grVar.hasNext()) {
        var tempVariable = {}
        tempVariable.Variable_Name = fieldName;
        tempVariable.Variable_Value = value;
		varArray.push(tempVariable);
	temp.Variables = varArray;
    taskInfo.push(temp);
    //return taskInfo;
    //return taskInfo;
return taskInfo;
15 REPLIES 15
@Suresh Loganathan
You can try the below code
var taskInfo = [];
    var varList = [];
    // grTask.setLimit(4);
    grTask.query();
        taskInfo.push({
        grVar.query();
                 varList.push({
            taskInfo.push(varList);
    gs.info(JSON.stringify(taskInfo)); //First try in background script
return taskInfo;
Muhammad Khan
@Suresh Loganathan
Use below script.
var taskInfo = [];
grTask.query();
    var temp = {};
    grVar.query();
		temp.Variables = {};
        temp.Variables.Variable_Name = fieldName;
		temp.Variables.value = value;
    //return taskInfo;
    //return taskInfo;
return taskInfo;
Hi Muhammed,
Your code is working but it''s bringing only one variable each catalog task. Can you help how to get complete variables on each catalog task?
Suresh.
@Suresh Loganathan
At first it looked like you were looking for just one variable, this should work for all variables.
var taskInfo = [];
grTask.query();
    var temp = {};
    grVar.query();
    //return taskInfo;
    //return taskInfo;
return taskInfo;
Hi Muhammed,
Still getting only one variable for each catalog task.
Suresh
