getEditableFields() is not working for reference field.
rajesh151
Mega Contributor
Kindly help if I missing anything or I have to add anything.
Rajesh
rajesh151
Mega Contributor
One thing to add, all are mandatory.
How can I make all mandatory field for all table also read only through client script and on load.
Madhava_Kumar
Mega Guru
Hi Rajesh,
Even I got the same problem.
I solved the problem with the below code, you will get all the fields which are editable and reference as well.
g_form.elements.forEach(function (e, i) {
g_form.setMandatory(e.fieldName, false);
g_form.setReadOnly(e.fieldName, true);
thanks
Madhava
Hi rajesh can u pls try this script
For ur requirement its working fine in my instance am currently using the Istanbul release
              var f=g_form.getEditableFields();
              for(var x=0;x<f.length;x++){
                      g_form.setReadOnly(f[x],true);
                      alert('all fields are read only');
