glideAggregate Sum not populating field
ssturde
Kilo Expert
I have parent records with child records. The child records each record unique values of impacted users. When I attempt to use glideAggregate to sum the individual child values into a single field in the parent record, I get no value returned.
Any help is appreciated:
var rec = new GlideAggregate('u_so_incident_impacts');
rec.groupBy('number');
rec.addAggregate('SUM','u_users_in_game_impacted');
rec.query();
while(rec.next()){
  var count = rec.getAggregate('SUM','u_users_in_game_impacted');
  var usam = count.addAggregate('SUM','u_total_users_impacted');
    current.u_total_users_impacted = usam;
  // find and store the count value in the related record.
I found the original script on another thread found here:
Add values from field on a related list
OK, here's the script I used in the calculated field on the dictionary entry for incident.u_total_users_impacted...
(function calculatedFieldValue(current) {
  var childTable = 'u_so_incident_impacts';
  var numberField = 'u_users_in_game_impacted'; // what do we want to sum up?
  var count = 0;
  var gr = new GlideRecord(childTable);
  gr.addQuery('u_parent', current.sys_id);
  while (gr.next()) {
  var n = parseInt(gr.getValue(numberField), 10);
  count += n;
  return count;   // return the calculated value
})(current);
Something to keep in mind... the calculated field isn't STORED in the database until you update the record. So you MAY incur performance issues if you present a list and it has to do all these gliderecord lookups to show you the list (assuming you put that field in the list layout.)
To improve performance, do a one-time forced-update to the incident records so it retally's the numbers and stores them. Going forward, they'll maintain themselves.
inc.query();
while (inc.next()) {
  inc.setWorkflow(false);
  inc.autoSysFields(false);
  inc.setForceUpdate(true);
  inc.update();
You can run this from scripts background or create a Fix script if you like (makes it easier to move from dev to prod in an update set.)
Fix Scripts - ServiceNow Wiki
30 REPLIES 30
Fantastic! Amazing! Awesome! Thank you so much! This worked perfectly. Sorry for the wild goose chase on glideAggregate. I appreciate you sticking with me through it all.
