GlideDialogWindow.get().destroy(); not working in Agent Workspace
chanikya
Hi ,
i used this function in UI Page, but GlideDialogWindow.get().destroy(); function not working in Agent Workspace.
how to kill dialogue box when we click on Cancel button
 UI PAge:
HTML:
 <g:dialog_buttons_ok_cancel ok="return validateComments()" cancel="return cancel()" ok_type="button" cancel_type="button" />
client script:
function validateComments() {
var businessservice=gel("input_business_service").value;
var comments = gel("dial_comments").value;
var contacttype=gel("HoldReason").value;
comments = trim(comments);
if ((comments == "" ){
return false;
g_form.setValue("comments", comments);
g_form.setValue('business_service',businessservice);
g_form.setValue('contact_type',contacttype);
return true;
function cancel()
return false;
 UI Action:
No , not working my end. any solution's to fix it?
Hey.. Did you find anything here?
ramwons
Kilo Expert
you got solution for this?
I also have same issue
ushakarthya
@chanikya
I am facing the same issue, did you find any solution/ workaround for this issue?
Thank you
I too, I just had the same problem, did you find a solution/workaround to this problem?
