Gliderecord in client script
Anirban Roy
Mega Guru
Why gliderecord query does not return results while using in client scripts for non-admin users?
e.g.
var group = g_form.getValue('assignment_group');
var user = g_user.userID;
var ir = new GlideRecord('sys_user_grmember');
ir.addQuery('group', group);
ir.addQuery('user', user);
ir.query();
if(ir.next()){
g_form.setValue('assigned_to', user);
alert(ir.sys_id+'if');
}else{
alert(ir.sys_id+'else');
  • If code runs with admin user logged/ impersonated, it alerts sys_id with 'if' string.
  • If code runs with a non admin user logged/ impersonated, it alerts 'undefined' with 'else' string.
PS: I know, we should not use do sync calls to server from client unless required, and also gliderecord should not be used in a client script/ or client side scripts. But I am curious to know the reason, that script behaves differently for admins and non-admins.
Anirban
The table glided is on 'sys_user_grmember', however I still tried to test by deactivating the before query BR you mentioned. Did not return result either with non-admin.
no, not the case.
You may try the example in personal instance.
Hi
Check the BR i.e user query which defines the sys_user(User table) only for admin(till kingston version) and for admin,user_admin(From London). Check that query BR.
Omkar Mone
That BR mudt be causing this kind of effect.
