Have to create write acl for few fields which are present in scoped application using script. Table and other fields are present in Global application. Whenever i click on advance for writing the script it makes it read only.
‎06-02-2020 02:23 AM
Not allowing to add script for ACL in scoped applications.
Please help!
Ajay Sharma
‎06-02-2020 04:09 AM
Hello Ajay,
This is the expected behavior. There is creation restriction across application scopes for few artifacts. Details here.
The only possible workaround is to create ACL as per the table scope i.e I guess global in this case.
- Pradeep Sharma
‎06-02-2020 04:24 AM
Hi Pradeep,
While creating the ACL in table scope i am not able to select those fields which are created in different scope.
Ajay Sharma
‎06-02-2020 05:06 AM
Hi Ajay,
Unfortunately no other way.
please create fields & field level ACLs in the same custom scope as the table scope.
‎06-02-2020 06:16 AM
Hey Ajay,
As I mentioned switch to the same app scope as of table scope and then create an ACL.
Please let me know if you have any questions.
- Pradeep Sharma
